0
Activate oversample in Arduino IDE for nrf52832
CSChris gravatar image
asked 2017-08-14 16:35:03 +0100
do I have a chance to activate oversample for an ADC by using Arduine IDE?
Best regards, Christian
edit retag flag offensive close delete report spam
Comments
1
See my answer in your previous question. You will have to modify the RBL Arduino library.
Jørgen Holmefjord ( 2017-08-14 17:10:46 +0100 )editconvert to answer
Hi Jørgen, thanks for your answer. Do you have any hint on examplary code? Maybe with sandeepmistry's libraries? https://github.com/sandeepmistry/ardu...
BR, Christian
Christian ( 2017-08-14 22:26:42 +0100 )editconvert to answer
1 answer
Sort by » oldest newest most voted
0
joh2 gravatar image
answered 2017-08-15 08:23:05 +0100
Something like this should work (based on the RedBear library):
wiring_analog.cpp
wiring_analog.h
You can then set oversampling using analogReadOversample(uint16_t oversample).
(I have not tested the code, so please let me know if there are any errors)
Jørgen
edit flag offensive delete publish link more
Comments
I have taken your code and put it into mine. It seems to work. With a resolution of 14 bit and 4x Oversampling the noise is cut to half. But it is still a very high noise. For higher oversampling rates the reading hardly gets better. Is any further trick for less noise available?
Christian ( 2017-08-15 11:33:35 +0100 )editconvert to answer
Please have a look at this answer from the SAADC designer.
Jørgen Holmefjord ( 2017-08-15 11:38:11 +0100 )editconvert to answer
Your Answer
Please start posting anonymously - your entry will be published after you log in or create a new account.
Add Answer. Do not ask a new question or reply to an answer here.
[hide preview]
User menu
    or sign up
Recent questions
Question Tools
1 follower
Stats
Asked: 2017-08-14 16:35:03 +0100
Seen: 69 times
Last updated: aug. 15
