Hi all
I've two questions regarding errata 156:
Am I assuming right that, as long as I don't use WFI or WFE, this errata has not effect?
Are the two consecutive TASK_CLR[n] and TASK_CLR[n+1], as described in the workaround, always setting the system back to the original mode? E.g. I want to use the LOWPOWER mode and trigger TASK_CLR[1] and afterwards TASK_CLR[2], does this restore the original mode (LOWPOWER) or does this switch to the CONSTLAT mode?
Many thanks in advance.
Kind regards
