I'm trying to integrate buttonless DFU with secure bootloader with bonds with the DFU. Using SDK 14 with SD 132 v5.0.0. Using projects: secure_dfu_ble, ble_app_hrs_freertos(modified with ble_app_buttonless_dfu)
Using the nRF connect for android, I can currently tell the embedded app to go to the BL, but the application does not continue with the DFU - it connects automatically to the embedded device in the BL mode (and sees the DFU services), but unable to continue there.
There's no error in the embedded size and app_error_handler_bare is not triggered.
However I'm seeing in the nRF connect's log that it's removing the bond information. Is that OK? Could be a reason that it's unable to proceed with the secure DFU. Then how can I test the DFU and when will the app be updated? If it is OK, what should I check?
Another note, in the secure_dfu_ble_s132 project, nrf_ble_dfu.c file, there's code that shouldn't be there:
uint16_t cccd;
ble_gatts_value_t value =
.len = BLE_CCCD_VALUE_LEN,
.offset = 0,
.p_value = (uint8_t*)&cccd
err_code = sd_ble_gatts_value_get(m_conn_handle, BLE_UUID_GATT_CHARACTERISTIC_SERVICE_CHANGED, &value);
NRF_LOG_DEBUG("CCCD for the service changed is 0x%04x", cccd);
in line 695. Was it added by mistake or should it be somewhere else?
Thanks in advance
