HEllo,
I was wondering whether or not is advisable to use the same handler to handle transmission/reception of data over SPI0 and SPI1 interfaces.
I have two sensors connected each one to each SPI, let's say sensorA to SPI0 and sensorB to SPI1, I have configured them like below, where it can be seen that I use different handlers for each one, but I wonder if I can combine both handlers into one, is that possible?
I would like to know as well how can I detect if my transmission is done for each SPI, so far I have something like this, but not sure whether it's efficent or not, am I going in the right way?
Thanks in advance
void spi_write_transfer(enableSPI spiInterfaceToUse, unsigned char slaveDeviceId, unsigned char* data, unsigned char bytesNumber) {
// Reset transfer done flag
spi_xfer_done_B = false;
spi_xfer_done_A = false;
if (spiInterfaceToUse == spiA) {
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi_A, data, bytesNumber, NULL, 0));
while (!spi_xfer_done_A) {
__WFE();
} else if(spiInterfaceToUse == spiB){
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi_B, data, bytesNumber, NULL, 0));
while (!spi_xfer_done_B) {
__WFE();
Handlers
void spi0_event_handler(nrf_drv_spi_evt_t const * p_event)
if(p_event->type == NRF_DRV_SPI_EVENT_DONE){
spi_xfer_done_A = true;
void spi1_event_handler(nrf_drv_spi_evt_t const * p_event)
spi_xfer_done_B = true;
SPIM configuration
uint32_t spis_start(enableSPI sensorToEnable){
uint32_t err_code;
// Enable the constant latency sub power mode to minimize the time it takes
// for the SPIS peripheral to become active after the CSN line is asserted
// (when the CPU is in sleep mode).
NRF_POWER->TASKS_CONSTLAT = 1;
// Configuring SPIM0 for the A
nrf_drv_spi_config_t spi_config_A = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config_A.ss_pin = SPIM0_SS_PIN;
spi_config_A.miso_pin = SPIM0_MISO_PIN;
spi_config_A.mosi_pin = SPIM0_MOSI_PIN;
spi_config_A.sck_pin = SPIM0_SCK_PIN;
// Configuring SPIM0 for the B
nrf_drv_spi_config_t spi_config_B = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config_B.ss_pin = SPIM1_SS_PIN;
spi_config_B.miso_pin = SPIM1_MISO_PIN;
spi_config_B.mosi_pin = SPIM1_MOSI_PIN;
spi_config_B.sck_pin = SPIM1_SCK_PIN;
//Initialising the sensor
switch(sensorToEnable){
case spiA:
NRF_LOG_INFO("spis_start trying to start SPI0");
err_code = nrf_drv_spi_init(&spi_A, &spi_config_A, spi0_event_handler);
case spiB:
NRF_LOG_INFO("spis_start trying to start SPI1");
err_code = nrf_drv_spi_init(&spi_B, &spi_config_B, spi1_event_handler);
case BOTH:
NRF_LOG_INFO("spis_start trying to start SPI0 & SPI1");
return err_code;
