I'm trying to implement a simple RTC timer into my project, and it seems like the app_timer module is the best way to do that, especially when using the Softdevice. I added the following code to my project in order to implement:
static void Handle_Timer(void * p_context){
UNUSED_VARIABLE(p_context);
void setTimerAndStart(void){
#define MILLISECOND 33
uint32_t err_code;
err_code = app_timer_start(Timer_A, 100*MILLISECOND, NULL);
void initTimer(void){
uint32_t err_code;
// Create battery timer.
err_code = app_timer_create(&Timer_A,
APP_TIMER_MODE_REPEATED,
Handle_Timer);
I also put an APP_TIMER_DEF(Timer_A) declaration at the top of the page and added appropriate calls into main.
If I try to call setTimerAndStart in my main loop after initializing it, the code stops working; it just loops through the main loop. I've tried stepping through it, but I haven't been able to get much usable information based on that (there's no error, at least as far as I can tell), and I've set a breakpoint at the handler in hardfault_implementation.c, but it doesn't trigger.
I'm using GCC and Eclipse, SDK 12.3, and softdevice s130 with an nRF51 devkit.
EDIT: here's some other relevant header stuff
#define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE 6 /**< Size of timer operation queues. */
