I'm following the tutorial Development with GCC and Eclipse, but have problem when use GCC to compile project that use PWM library.
I found that when compile the code with GNU "make" command, whenever I call app_pwm_disable(), the PWM stops. If call app_pwm_uninit() after app_pwm_disable(), PWM start to work, but it will break the BLE connection. Exactly the same code works fine when I build it with Keil, so I guess it's something related with GCC compiler. The code and makefile I'm using is the ble characteristic tutorial, and I use SDK 11, PCA10028.
Thanks for any help!
