I'd like to use nrfjprog to read contents of QSPI external memory. (I'm using an nRF52840-QIAA on a custom PCB, based on the PDK.)
Using application firmware I am able to successfully read and write to my external flash chip. I'm also able to dump the contents using --readqspi.
nrfjprog --readqspi ./test.txt -f nrf52
:020000041200E8
:10000000ADDE00000000FFFFFFFFFFFFFFFFFFFF6F
:10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
:10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
I want to read a portion of the external flash memory using --memrd, as the nrfjprog documentation says should be possible. I'm not sure how to translate address 0x0000 of external flash into an address for --memrd. Just using the literal address doesn't seem to work:
nrfjprog --memrd 0x0000 --n 16 --w 8 -f nrf52
0x00000000: 00 04 00 20 E5 08 00 00 79 05 00 00 C5 08 00 00 |... ....y.......|
Thinking I need to offset the address to the start of the XIP region. If so, what is the correct way to do that?
I am using the QspiDefault.ini that came with the SDK.
Thanks!
