I posted recently about having used the app_uart
driver and having problems with an overflow breaking uart receive (devzone.nordicsemi.com/.../)
I decided to try with app_uart_fifo
and see if that was any better, but I'm still getting 'overflow' problems.
In fact, looking at the code, app_uart_fifo
calls nrf_drv_uart_rx(..., rx_buffer, 1)
- so it seems that even if I've allocated a 256 byte buffer for my fifo, and uarte is enabled, the hardware itself won't be used and I'll still get hardware overflow errors if an IRQ occurs at the wrong time at higher baud rates.
Is this the case? I'm using SDK12.3 but it looks to be the same in SDK14 as well.
Are there any examples/libraries available that use the UARTE hardware with a circular buffer, so I can be sure that I won't get overflows - or is there a hardware problem which means it can't be done? It seems odd that Nordic's own libraries don't use it.
thanks!
