I'm trying to use examples/ble_peripheral/ble_app_uart
with SDK-14 and NRF52 DK (pca10040).
The test case is very simple, I use python script to write data to /dev/ttyACM0
, the data is splitted into chunks of predefined size. Newline character is appended to each chunk.
On the other side I open nRF Connecitivity app on Android and I connect to the dev kit, enable notifications on TX characteristic and wait for the data to come. (I start the script after notifications are enabled)
This is the RTT output I get after starting the test script:
Process: JLinkExe
<warning> nrf_sdh_ble: RAM start should be adjusted to 0x20002760.
<warning> nrf_sdh_ble: RAM size should be adjusted to 0xD8A0.
<info> app: UART Start!
<info> app: Connected
<error> ble_gatt: sd_ble_gap_data_length_update() (request) on connection 0x0 returned unexpected value 0x13.
<info> app: Data len is set to 0x3D(61)
<error> app: Fatal
test.py:
#!/usr/bin/env python2.7
import base64
import serial
from time import sleep
CHUNK_SIZE=10
def chunkstring(string, length):
return (string[0+i:length+i] for i in range(0, len(string), length))
lorem = '''
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nulla interdum ornare purus a egestas. Proin blandit diam erat. Ut vitae orci luctus lacus accumsan vehicula feugiat a leo.
encoded_string = ''.join('{:02x}'.format(ord(c)) for c in str(lorem))
chunks = list(chunkstring(encoded_string, CHUNK_SIZE))
with serial.Serial('/dev/ttyACM0', baudrate=115200, rtscts=True) as ser:
for c in chunks:
c += '\n'
ser.write(c)
print(c)
I noticed that the test works if sleep(1)
is added to the writing loop.
