We use NRF52832-based BLE module running serialization (SDK 14, softdevice 5.0.0) and STM32F407 MCU running application firmware on a custom board. The project is created in Eclipse and compiled using GCC. Also there is micro SD card that is used to store logs over SPI interface. We faced strange issue: once connection is established we get hardfault when the very first log is being written onto SD card. Our guess that the reason is in using sections in SDK 14. Previously we worked with SDK 13 and there were not any problems with storing logs. Maybe the reason is that we didn't use modules that work with sections (for instance .fs_data
and .pwr_mgmt_data
The questions are:
- Could it be that using sections is the reason of issue?
- If yes, how we can fix the issue or avoid using sections?
- If no, what also could be the reason?
I've attached linker script for more details:
Also we've discovered that one of the sections contains information which is not used by the SDK. Here is a part of such section dump:
0807f9b8 <sdh_soc_observers>:
807f9b8: 08086178 08086180 00000008 6e5c2e2e xa...a........\n
807f9c8: 535f4652 315f4b44 6f735c34 65647466 RF_SDK_14\softde
807f9d8: 65636976 66726e5c 6864735f 636f735f vice\nrf_sdh_soc
807f9e8: 0000632e 2d6a626f 6e69703e 203d2120 .c..obj->pin !=
807f9f8: 6e695028 656d614e 00434e29 445c3a44 (PinName)NC.D:\D
807fa08: 73696e65 65726853 72656269 726f775c enisShreiber\wor
807fa18: 6170736b 655c6563 6170657a 6d5c6b72 kspace\m
807fa28: 5c646562 6465626d 6c61685c 7261745c bed\mbed\hal\tar
807fa38: 73746567 6c61685c 5241545c 5f544547 gets\hal\TARGET_
807fa48: 5c4d5453 47524154 535f5445 32334d54 STM\TARGET_STM32
807fa58: 672f3446 5f6f6970 656a626f 682e7463 F4/gpio_object.h
807fa68: 00000000 735c2e2e 625c6372 632e656c ......\src\ble.c
807fa78: 00007070 75257a45 00000000 70657a45 pp..Ez%u....Ezep
807fa88: 006b7261 454c425b 5053523a 00003a5d .[BLE:RSP]:..
807fa98: 5f444d43 5f505352 43435553 00535345 CMD_RSP_SUCCESS.
807faa8: 5f444d43 5f505352 48434554 5353495f CMD_RSP_TECH_ISS
807fab8: 00004555 5f444d43 5f505352 425f4f4e UE..CMD_RSP_NO_B
807fac8: 4e414c41 455f4543 5245544e 00000000 ALANCE_ENTER....
Here is an example of four section dumps without data from user application:
0807f95c <sdh_req_observers>:
807f95c: 08086110 08086110 00000008 .a...a......
0807f968 <sdh_state_observers>:
807f968: 08086110 08086110 00000008 .a...a......
0807f974 <sdh_stack_observers>:
807f974: 08086100 08086110 00000008 00020100 .a...a..........
0807f984 <sdh_ble_observers>:
807f984: 08086110 08086178 00000008 6e5c2e2e .a..xa........\n
807f994: 535f4652 315f4b44 6f735c34 65647466 RF_SDK_14\softde
807f9a4: 65636976 66726e5c 6864735f 656c625f vice\nrf_sdh_ble
807f9b4: 0000632e .c..
Update #1.
Here is the code where hardfault is happening:
int SPI::write(int val) {
lock(); // <-- fault. This is the empty function
aquire();
Disassembler:
str r1, [r7, #0]
lock();
ldr r3, [r7, #4]
ldr r3, [r3, #0]
adds r3, #4
ldr r3, [r3, #0]
ldr r0, [r7, #4]
blx r3 // <-- fault
aquire();
Before BLX command R3 = 0x1FBBC00. This address is out of range STM32 memory map.
Probably the reason of fault is stack overflow. I tried to increase stack of thread where SD card is used but it did'n help. I use mbed RTOS.
