I ran into the issue where the clock definitions were defined in both the "board_pcaXXX.h" file and the sdk_config.h.
e.g. NRF_SDH_CLOCK_LF_XTAL_ACCURACY NRF_SDH_CLOCK_LF_SRC NRF_SDH_CLOCK_LF_RC_CTIV NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
I didn't realize they had moved to sdk_config.h, and obviously, when I tried to compile and run with different clock parameters set in the board specific file, they were not picked up and trouble continued.
After realizing they moved to sdk_config.h, my problem was fixed, but I note that typically these parameters are "board"-specific, and not "SDK" specific -- and ideally should be placed in the board specific package. I've made that change locally, but it will cause much grief when I have to remember to remove it from the next SDK_CONFIG.H file.
What's the strategy here for these parameters? I believe it should be reviewed and conveyed.
