BPROT Protecting Bootloader nRF52832
nRF52832 SDK14.0
Hi, how can I protect the bootloader from being overwritten? Ideally, I would never be updating the bootloader so it will be a permanent part of the device. How can I make sure nothing can overwrite/erase the bootloader? I am looking at BProt, but I am not a 100% sure on how to implement it. Can you please give me an example on how I would go about doing this?
Thank you!
Best!
    Yes, you can use the BPROT peripheral to prevent application code from erasing or writing to protected blocks. Any attempt to erase or write to a protected flash page will trigger a hardfault. Typically, you would want to enable the protection right at the start of your code, before you do anything else.
    A BPROT-block represents 1 flashpage(4kB), so on the nRF52832 that have 512 kB flash, we have 512/4 = 128 BPROT-blocks. The non-debug secure-bootloader in SDK 14.0 is by-default located from 0x78000 to 0x7E000. This corresponds to BPROT block/region 120 to 126. (The debug-project uses page 115 to 124).
    You can enable BPROT on these regions like this:
    NRF_BPROT->CONFIG3 = (BPROT_CONFIG3_REGION120_Enabled << BPROT_CONFIG3_REGION120_Pos) |
                         (BPROT_CONFIG3_REGION121_Enabled << BPROT_CONFIG3_REGION121_Pos) |
                         (BPROT_CONFIG3_REGION122_Enabled << BPROT_CONFIG3_REGION122_Pos) |
                         (BPROT_CONFIG3_REGION123_Enabled << BPROT_CONFIG3_REGION123_Pos) |
                         (BPROT_CONFIG3_REGION124_Enabled << BPROT_CONFIG3_REGION124_Pos) |
                         (BPROT_CONFIG3_REGION125_Enabled << BPROT_CONFIG3_REGION125_Pos) |
                         (BPROT_CONFIG3_REGION126_Enabled << BPROT_CONFIG3_REGION126_Pos);
  • Thank you very much for the clear answer, Sigurd!
