I'm migrating from sdk13 to sdk14 with work app. Can't solve one weird problem. When my app start first time I initialize some data with saving by fds library to flash. There were no any problem to do it in sdk 13. Now I save all data good except two intead of saving my values (0x0000 and 0x0001) it saves something weird 0x200034BC
ret_code_t fds_write_value(uint32_t* value, uint16_t file_id, uint16_t rec_key)
fds_record_desc_t record_desc;
fds_record_t record;
// Set up record.
record.file_id = file_id;
record.key = rec_key;
record.data.p_data = value;
record.data.length_words = 1;
write_flag = 0;
ret_code_t ret = fds_record_write(&record_desc, &record);
if (ret != FDS_SUCCESS)
return ret;
SEGGER_RTT_printf(0,"Writing Record ID = %d, value = %d\r\n",record_desc.record_id, *value);
return NRF_SUCCESS;
in RTT terminal I see right values, but then I go into debug mode and check memory, there are wrong values
here's my values definition the same I can see in terminal but in memory I can see that "11" value is updated to something wrong, and second just wrong.
