UART Peripheral Dead?
I've been developing an application on the nrf51 DK based on the ble uart application and it's been working fine. I've ported it to a custom board running at 1.8V and attached a 1.8V USB-UART adaptor to debug the UART output but after printing a few messages it stopped working.
Now whenever I try to do a printf or any other kind of TX on the UART interface I get an APP_UART_COMMUNICATION_ERROR with error code 4. I can still toggle the lines manually when configured as GPIOs.
Any thoughts on what might have happened or how to debug if the uart is really dead?
EDIT:
I ended up commenting out the call to APP_ERROR_HANDLER in the UART ISR and now things are working as expected. I guess the UART goes into a bad state on the first attempt to transmit and the error handler just resets the device?
/**@brief UART event handler
	static uint8_t data_array[256];
	static uint8_t index = 0;
	uint32_t       err_code;
	switch (p_event->evt_type)
		case APP_UART_DATA_READY:
			index++;
			//APP_ERROR_HANDLER(p_event->data.error_communication);
		case APP_UART_FIFO_ERROR:
			//APP_ERROR_HANDLER(p_event->data.error_code);
EDIT:
It turns out the RX line floating was causing issues.
