Hi, I am using NRF51822 and GCC compiler. I am using softdevice S130. SDK 12.2. I want to receive the data from Peripheral that is one way only. I want to use multilink central application on NRF51822. When i compile the code then i got the error as
/usr/local/gcc-arm-none-eabi-5_4-2016q3/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: region RAM overflowed with stack
I checked in Makefile, Heap size is zero only. How can i use the nrf51822 to fit this application? i changed the RAM area as
RAM (rwx) : ORIGIN = 0x20001fe8, LENGTH = 0x2018
Is it possible to use other SD and reduce some more RAM?
