I am simply trying to add a custom service to the HRS example. When I build in regular s132
armgcc it works no problem shows my blank service with nothing special. however when I build armgcc s132_with_dfu
device no longer shows in nrfConnect.
I will attach a zip of the code but from what I have gathered these are the important bits.
service init
uint32_t err_code;
ble_hrs_init_t hrs_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
uint8_t body_sensor_location;
our_service_init(&m_our_service);
// Initialize Heart Rate Service.
body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
memset(&hrs_init, 0, sizeof(hrs_init));
hrs_init.evt_handler = NULL;
hrs_init.is_sensor_contact_supported = true;
hrs_init.p_body_sensor_location = &body_sensor_location;
// Here the sec level for the Heart Rate Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
err_code = ble_hrs_init(&m_hrs, &hrs_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
(&bas_init.battery_level_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
(&bas_init.battery_level_char_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
err_code = ble_dis_init(&dis_init);
#ifdef BLE_DFU_APP_SUPPORT
/** @snippet [DFU BLE Service initialization] */
ble_dfu_init_t dfus_init;
// Initialize the Device Firmware Update Service.
memset(&dfus_init, 0, sizeof(dfus_init));
dfus_init.evt_handler = dfu_app_on_dfu_evt;
dfus_init.error_handler = NULL;
dfus_init.revision = DFU_REVISION;
err_code = ble_dfu_init(&m_dfus, &dfus_init);
dfu_app_reset_prepare_set(reset_prepare);
dfu_app_dm_appl_instance_set(m_app_handle);
#endif // BLE_DFU_APP_SUPPORT
ble init
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
ble_enable_params.common_enable_params.vs_uuid_count = 4;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
ble_enable_params.gatts_enable_params.service_changed = 1;
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
err_code = softdevice_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
Link File
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
FLASH (rx) : ORIGIN = 0x1c000, LENGTH = 0x64000
RAM (rwx) : ORIGIN = 0x20001fe8, LENGTH = 0xe018
SECTIONS
.fs_data :
PROVIDE(__start_fs_data = .);
KEEP(*(.fs_data))
PROVIDE(__stop_fs_data = .);
} > RAM
} INSERT AFTER .data;
INCLUDE "nrf5x_common.ld"
our_service.c
#include <stdint.h>
#include <string.h>
#include "our_service.h"
#include "ble_srv_common.h"
#include "app_error.h"
#include "SEGGER_RTT.h"
void our_service_init(ble_os_t * p_our_service)
uint32_t err_code = 0; // Variable to hold return codes from library and softdevice functions
SEGGER_RTT_WriteString(0, "Service Entry.\n");
// OUR_JOB: Declare 16-bit service and 128-bit base UUIDs and add them to the BLE stack
ble_uuid_t service_uuid;
ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID;
service_uuid.uuid = BLE_UUID_OUR_SERVICE;
err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
// OUR_JOB: Add our service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&service_uuid,
&p_our_service->service_handle);
