I am getting random data while using saadc example to reading analog voltage applied to pin on nrf52840. i want to read analog output from MQ135 gas sensor, I have applied the voltage output from sensor to P0.06 and reading the output from termite but all i am getting is random data with no meaning.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_power.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
ret_code_t err_code;
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
int i;
NRF_LOG_INFO("ADC event number: %d\r\n", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
NRF_LOG_INFO("%c\r\n", p_event->data.done.p_buffer[i]);
m_adc_evt_counter++;
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
uint32_t err_code = NRF_LOG_INIT(NULL);
err_code = nrf_drv_power_init(NULL);
ret_code_t ret_code = nrf_pwr_mgmt_init();
APP_ERROR_CHECK(ret_code);
NRF_LOG_INFO("SAADC HAL simple example.\r\n");
saadc_init();
saadc_sampling_event_init();
while (1)
nrf_pwr_mgmt_run();
NRF_LOG_FLUSH();
I keep getting output in termite - terminal like this :
[00]€[05]@…[05][00]Ù–ð[00]ý¨Q8[00]Æ[06][00][00][05]@…[01][03][00][05]@…[01][00][00][05][1C][05]…[01][00][00][05]@…[01][00][00][01]@_x[00][00]APP:INFO:ADC event number: 434
APP:INFO:[03]
APP:INFO:[00]
APP:INFO:[02]
APP:INFO:[02]
APP:INFO:[02]
APP:INFO:ADC event number: 435
But cannot get the actual value.
