Related to SDK 12.3.
Quoting this question:
- GPIOTE PORT event generated on the rising edge of DETECT signal. Please have a look at section 15.1.2
2)DETECT signal is common signal when multiple pins are configured with SENSE mechanism. The DETECT signal is only cleared when all of the pin with SENSE mechanism is inactive. So if there still one pin is active, you won't be able to receive another interrupt on GPIOTE PORT event.
What does Inactive mean ?
Consider a pin is configured to sense HITOLO. Is High considered inactive and Low considered active?
When a falling edge happens, I receive the interrupt, but do nothing to change the pin status, meaning that it will remain LOW. While this pin is LOW, will I be able to receive any other GPIOTE events? Or does the pin have to return to HIGH in order to release the DETECT signal?
