Hello, I have a strange behaviour in my project and can't find the cause: I have connected a TMP116 temperature sensor using TWI with SDA at P0.03 and SCL at P0.04 using internal Pull-Ups, 100 kHz clock frequency. At my oscilloscope at the SDA pin I see that the sensor delivers correct values; only nrf_drv_twi_rx() delivers all the time 0x00 and I don't know why...
The configuration is done by:
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_tmp116_config = {
.scl = TWI_SCL_PORT, // P0.04
.sda = TWI_SDA_PORT, // P0.03
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_tmp116_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
Actually every 2 seconds the function read_sensor_data() is called:
static void read_sensor_data()
int16_t l_i16HexWert;
uint8_t rx_buf[4] = {0};
m_xfer_done = false;
/* Writing to pointer byte. */
err_code = nrf_drv_twi_tx(&m_twi, TMP116_ADDR, ®_Temp[0], 1, false);
while (m_xfer_done == false);
err_code = nrf_drv_twi_rx(&m_twi, TMP116_ADDR, &rx_buf[0], 2);
/* while (m_xfer_done == false); */
// for additional debugging info
ui32TWI_Enable = *(uint32_t *) 0x40003500UL; // Read TWI Enable
ui32TWI_PSELSCL = *(uint32_t *) 0x40003508UL; // Read PSELSCL
ui32TWI_PSELSDA = *(uint32_t *) 0x4000350CUL; // Read PSELSDA
ui32GPIO_IN = *(uint32_t *) 0x50000510UL; // Read GPIO
ui32GPIO_DIR = *(uint32_t *) 0x50000514UL; // Read GPIO
ui32GPIO_CONFPORT3 = *(uint32_t *) 0x5000070CUL; // Read GPIO
ui32GPIO_CONFPORT4 = *(uint32_t *) 0x50000710UL; // Read GPIO
ui32TWI_ERRORSRC = *(uint32_t *) 0x400034C4UL; // Read TWI ErrorSrc Register
// calculate temperature
l_i16HexWert = (int16_t)rx_buf[0];
l_i16HexWert = l_i16HexWert << 8;
l_i16HexWert += (int16_t)rx_buf[1];
m_sample = (uint8_t)((int16_t) (l_i16HexWert >> 7));
When I check the registers I see that the
TWI_ENABLE register contains the value 5 -> ok
PSELSCL register contains the value 4 -> ok
PSELSDA register contains the value 3 -> ok
GPIO_IN register contains 0x201418, by this a '1' at the bit positions 3 and 4 -> probably ok with pull-ups
GPIO_DIR register contains 0x100000, by this a '0' at the bit positions 3 and 4 -> probably ok as inputs
configuration registers of Port 0.03 and 0.04 contain 0x060c -> S0D1 (standard for wired and connections), with pull-ups, input function, connect input buffer
TWI ERRORSRC: 0x00
so everything should be fine...
Does anybody have an idea?
