How to implement Ctrl-C for HID keyboard
Hi Guys, I try to implements the ctrl-C/V for bluetooth HID keyboard. But from SDK, I can't figure out how to send two keys. Even I do not use buffer_enqueue/dequeue in order to keep 'Ctrl' pressed, not released, still can't work. Does anyone figure out how to work on it?
  • I have no clue how the SDK for HID or HID on bluetooth work, but in case it can help, on a regular keyboard you have "make" and "break" codes. You would send a "Ctrl" make (press) then a "C" make, then C break (release) and Ctrl break.
    From what I remember on USB HID (just checked 5-10 years old code), I'd get reports of X bytes, where X is the maximum amount of key presses keyboard would handle. In your case, let's imagine you support 8 keys, you'd first send a report (sorry, that's USB HID terminology, I don't know if they use the same in Bluetooth HID, take it as "packet" otherwise) with first byte indicating Ctrl, then 7 bytes to 0. Then a report with 1st byte indicating Ctrl, 2nd one indicating "C", then 6 bytes to 0. Then back to Ctrl in 1st byte and 7x 0 bytes, then a report with 8x 0 (not necessary, most OSes will only require C to be released to perform action, but nice to be clean and not have "ghost" keys).
    Hope that helps!
  • Thanks Jonathan. The Bluetooth HID is the same way like USB HID and I just lost in the SDK files. The SDK only support press-release mode, it's hard to implement press-hold-release mode.
    I just checked what are escape codes for "ctr+c" and "ctr+v". I did it by debugging function: cli_state_collect in nrf_cli module.
    Here are escape codes:
    • ctr+c = 0x03
    • ctr+v = 0x16
    To handle it I would need to update cli_state_collect function with two extra cases in below switch statement:
    switch (data)
        case NRF_CLI_VT100_ASCII_ESC:       /* ESCAPE */
            NRF_CLI_RECIEVE_STATE_NEXT(p_cli, NRF_CLI_RECEIVE_ESC);
        case '\0':
        case '\t':                          /* TAB */
            cli_tab_handle(p_cli);
        case NRF_CLI_VT100_ASCII_BSPACE:    /* BACKSPACE */
            char_backspace(p_cli);
        case NRF_CLI_VT100_ASCII_DEL:       /* DELETE */
            char_delete(p_cli);
        case 0x03   // ctr+c
        case 0x16:  // ctr+v
            if (isprint((int)data))
                char_insert(p_cli, data);
  • The HID Usage tables, page 53, shows the codes for each key:
    www.usb.org/.../Hut1_12v2.pdf
    And the byte ordering is as following:
    Byte 0: Keyboard modifier bits (SHIFT, ALT, CTRL etc)
    Byte 1: reserved
    Byte 2-7: Up to six keyboard usage indexes representing the keys that are currently "pressed".
    On page 59, you can see that Keyboard LeftControl have Usage ID 224 / 0xE0.
    When a key is released, the specific key should be cleared (write 0 to it).
    The modifier byte is normally called "modifier keys". This is standardized as shown here in the mbed USB documentation:
    docs.mbed.com/.../md_doc_HID.html
    Note that when you're holding down one of these buttons, you will also have to release the key afterwards. If not, the PC/phone will not execute the command properly.
