I have a number of nRF52832 beacons that advertise at a set interval. All the beacons have a "device_name" set as "ECO". My application scans for these beacons with the device_name == "ECO". When the application reads a beacon device_name of "ECO", I then read the beacon MAC address of the beacon with the best RSSI. However my problem is that when I parse the device name, I am reading beacons with other device_name. There seems to be a problem with my parsing of the scanned device_name.
My Code:
static uint32_t adv_report_parse(uint8_t type, uint8_array_t * p_advdata, uint8_array_t * p_typedata)
uint32_t index = 0;
uint8_t * p_data;
p_data = p_advdata->p_data;
while (index < p_advdata->size)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index + 1];
if (field_type == type)
p_typedata->p_data = &p_data[index + 2];
p_typedata->size = field_length - 1;
return NRF_SUCCESS;
index += field_length + 1;
return NRF_ERROR_NOT_FOUND;
/**@brief Function for handling the Application's BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code = 0;
const ble_gap_evt_t * p_gap_evt = &p_ble_evt->evt.gap_evt;
uint8_array_t adv_data;
uint8_array_t dev_name;
bool found_name = false;
int count;
case BLE_GAP_EVT_ADV_REPORT:
const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
// Prepare advertisement report for parsing.
adv_data.p_data = (uint8_t *)p_gap_evt->params.adv_report.data;
adv_data.size = p_gap_evt->params.adv_report.dlen;
// Search for advertising names.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
&adv_data,
&dev_name);
if (err_code != NRF_SUCCESS)
// Look for the short local name if it was not found as complete.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name);
// If we can't parse the data, then exit.
return;
found_name = true;
found_name = true;
if (found_name)
if (strlen(m_target_periph_name) != 0)
if (memcmp((char*)dev_name.p_data,m_target_periph_name , dev_name.size) == 0)
if(last_beacon.rssi < p_adv_report->rssi)
for(count = 0;count < 6; count++)
last_beacon.addr[count] = p_adv_report->peer_addr.addr[5-count];
last_beacon.rssi = p_adv_report->rssi;
cPrintLog(CDBG_FCTRL_INFO,"found beacon : %s\n",dev_name.p_data );
cPrintLog(CDBG_FCTRL_INFO,"Scanning target: %02x%02x%02x%02x%02x%02x\r\n",
p_adv_report->peer_addr.addr[0],
p_adv_report->peer_addr.addr[1],
p_adv_report->peer_addr.addr[2],
p_adv_report->peer_addr.addr[3],
p_adv_report->peer_addr.addr[4],
p_adv_report->peer_addr.addr[5]
}break; // BLE_GAP_EVT_ADV_
