A strange problem about download and debug
619772263@qq.com gravatar image
asked 2017-10-13 07:07:54 +0200
Hello, I made some boards on nrf52832 and I was testing the PCB.
The test program is ..\nRF5_SDK_12.0.0_12f24da\examples\ble_peripheral\ble_app_hrs.
(I have downloaded the softdevice s132 3.0.0)
Here the appearance as follows:
  • In debug mode:
image description and run, everything is fine.
  • In download mode:
image description image description
can scan the advertise, but can't connect.
So I add uart to print some error message in download mode. And I find it will run into app_error_fault.
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    error_info_t* error_info = (error_info_t*)info;
    memset(error_buffer, 0x00, sizeof(error_buffer));
    printf(
            "app_error file_name: %s, line_num: %d, err_code: %08X\r\n",
            error_info->p_file_name, error_info->line_num, error_info->err_code
And the uart print message is :
app_error file_name: KGJ`h侒園h, line_num: 1024, err_code: 00000579
But I can't find any error code about 579. What is the reason?
Is the chip wrong or my board design? Or else?
I need you help!
edit retag flag offensive close delete report spam
Comments
If I comment power_manage();
it run well both in Debug and direct download mode.
What's wrong? So confuced...
fanleung ( 2017-10-14 11:38:13 +0200 )editconvert to answer
Hi fanleung. So the HRS example works fine when you debug? But not when pressing download?
And when you comment out power_manage(); it works fine for both? Did you make any modifications to the code?
Joakim Jakobsen ( 2017-10-17 08:52:26 +0200 )editconvert to answer
Hi, jakobsen. I didn't make any modifications to the HRS.
But I fould the problem out. My SDK is 12.0.0 and the pack is 8.7.1.
When I update the newest, it run well both Debug and download mode.
The Errata No.108: “RAM content cannot be trusted upon waking up from System ON Idle or System OFF mode”
fanleung ( 2017-10-17 09:03:06 +0200 )editconvert to answer
I'm happy you were able to solve the problem.
Thanks for sharing the solution.
Joakim Jakobsen ( 2017-10-17 09:05:53 +0200 )editconvert to answer
This problem bothered me few day...
In the production, some of the chip performance is normal, but few are so strange.
I think it is necessary to update SDK, sd and pack frequently...
fanleung ( 2017-10-17 09:16:40 +0200 )editconvert to answer
Yes, I would really recomment to use the latest SDK with support for your device. As you are using the nRF52832 the latest version is SDK v.14.0.0.
Joakim Jakobsen ( 2017-10-17 10:01:52 +0200 )editconvert to answer
