hi
I write a function getT()
to read spi thermalcouple chip.
if the function getT()
is called in main()
function, it will work correctly. Hence, I think that getT()
is correct essentially.
is called when BSP_EVENT_KEY4
is triggered(in function bsp_event_handler
), the function getT()
does not work correclty.
Trace the codes, I find the function spi_event_handler()
does not be called and causes err_code = NRF_ERROR_BUSY
in function nrf_drv_spi_xfer
I.E. the funtion spi_event_handler()
will not be called after the funtion bsp_event_handler()
is called.
The following is part of my codes:
spi_config();
getT();
In above code, the function getT()
in the main() block is work correctly.
static void bsp_event_handler(bsp_event_t event)
switch (event) {
case BSP_EVENT_KEY_4:
getT();
can not work correctly when it is put in the bsp_event_handler
block.(The spi_event_handler
does not be called)
How can I fixed this issue?
Thank you for your help. Best Wishes
