NRF51, SDK 12, FDS Issue(s)
I am not able to make the FDS work. Here is my setup
  • NRF51
  • SDK 12.3
  • S130 (2.0.1), i.e. s130_nrf51_2.0.1_softdevice.hex
  • Using peer manager as well
sdk_config.h:
// <e> FDS_ENABLED - fds - Flash data storage module
#ifndef FDS_ENABLED
#define FDS_ENABLED 1
#if  FDS_ENABLED
// <o> FDS_OP_QUEUE_SIZE - Size of the internal queue.
#ifndef FDS_OP_QUEUE_SIZE
#define FDS_OP_QUEUE_SIZE 5
// <o> FDS_CHUNK_QUEUE_SIZE - Determines how many @ref fds_record_chunk_t structures can be buffered at any time.
#ifndef FDS_CHUNK_QUEUE_SIZE
#define FDS_CHUNK_QUEUE_SIZE 8
// <o> FDS_MAX_USERS - Maximum number of callbacks that can be registered.
#ifndef FDS_MAX_USERS
#define FDS_MAX_USERS 4
// <o> FDS_VIRTUAL_PAGES - Number of virtual flash pages to use.
// <i> One of the virtual pages is reserved by the system for garbage collection.
// <i> Therefore, the minimum is two virtual pages: one page to store data and
// <i> one page to be used by the system for garbage collection. The total amount
// <i> of flash memory that is used by FDS amounts to @ref FDS_VIRTUAL_PAGES
// <i> @ref FDS_VIRTUAL_PAGE_SIZE * 4 bytes.
#ifndef FDS_VIRTUAL_PAGES
#define FDS_VIRTUAL_PAGES 3
// <o> FDS_VIRTUAL_PAGE_SIZE  - The size of a virtual page of flash memory, expressed in number of 4-byte words.
// <i> By default, a virtual page is the same size as a physical page.
// <i> The size of a virtual page must be a multiple of the size of a physical page.
// <256=> 256
// <512=> 512
// <1024=> 1024
#ifndef FDS_VIRTUAL_PAGE_SIZE
#define FDS_VIRTUAL_PAGE_SIZE 256
#endif //FDS_ENABLED
// </e>
// <e> FSTORAGE_ENABLED - fstorage - Flash storage module
#ifndef FSTORAGE_ENABLED
#define FSTORAGE_ENABLED 1
#if  FSTORAGE_ENABLED
// <o> FS_QUEUE_SIZE - Configures the size of the internal queue.
// <i> Increase this if there are many users, or if it is likely that many
// <i> operation will be queued at once without waiting for the previous operations
// <i> to complete. In general, increase the queue size if you frequently receive
// <i> @ref FS_ERR_QUEUE_FULL errors when calling @ref fs_store or @ref fs_erase.
#ifndef FS_QUEUE_SIZE
#define FS_QUEUE_SIZE 4
// <o> FS_OP_MAX_RETRIES - Number attempts to execute an operation if the SoftDevice fails.
// <i> Increase this value if events return the @ref FS_ERR_OPERATION_TIMEOUT
// <i> error often. The SoftDevice may fail to schedule flash access due to high BLE activity.
#ifndef FS_OP_MAX_RETRIES
#define FS_OP_MAX_RETRIES 3
// <o> FS_MAX_WRITE_SIZE_WORDS - Maximum number of words to be written to flash in a single operation.
// <i> Tweaking this value can increase the chances of the SoftDevice being
// <i> able to fit flash operations in between radio activity. This value is bound by the
// <i> maximum number of words which the SoftDevice can write to flash in a single call to
// <i> @ref sd_flash_write, which is 256 words for nRF51 ICs and 1024 words for nRF52 ICs.
#ifndef FS_MAX_WRITE_SIZE_WORDS
#define FS_MAX_WRITE_SIZE_WORDS 256
#endif //FSTORAGE_ENABLED
// </e>
Using basically this example in our application.
What happens:
  • Writing doesn't return any error
  • However FDS callback is never triggered!
  • When trying to read, getting error FDS_ERR_NOT_FOUND when using fds_record_find(). Weird as write, didn't return any error.
As far as I have searched, I have seen some related topics, but not a single answer. E.g.:
Any clues? Any debug-direction? Thanks!
EDIT 1:
After doing some debugging my self this what is happening:
FDS:
  • queue_process() is called
  • which calls write_execute()
  • which calls record_header_write_begin(), which returns 0x00 (=FDS_OP_EXECUTING or FDS_SUCCESS)
  • I see the next step is: p_op->write.step = FDS_OP_WRITE_RECORD_ID;, but is never executed! Probably because queue_process(result); is never called, because fs_event_handler() in fds.c is never called. But why?
EDIT 2:
I just run the example, just the main.c with SDK 12.3 and it has the exact same behavior...!
