Hi All, We have a data logging application, where our typical data packet is small -- roughly 20 bytes. I've been experimenting with FDS for storage, with one record for each packet, and I'm getting my fds write calls returning with an error (7) -- out of memory -- at 200 records. The record count went down and I could write blocks again once the garbage collector ran.
I would like to be able to store thousands of records -- ideally use most of free flash.
- Is every data packet stored in its own flash block (presumably 1k) or does FDS have the ability to pack the data into flash blocks?
- Is this a configuration problem, or a limitation of FDS?
I am currently porting from SDK11 to SDK12.3 (S132) on a 52832. I plan to roll the application to SDK14 in the near future.
