I have a BLE-Nano v1.5 board with 32KB of ram starting at address 0x20000000 (til 0x20008000). However when I want to read a byte of the uper 16K (0x2004000+), I get a 'cannot acces memory error'. The debugger is a MK20 usb board.
According to the following registers the MPU is disabled:
PERR0=0
RLENR0=1635459840
PROTENSET0=0
PROTENSET1=0
DISABLEINDEBUG=1
PROTBLOCKSIZE=0
Information about ram in the FICR registers confirm the specs of my board:
NUMRAMBLOCK=4
SIZERAMBLOCKS=8192
The rams are also powered:
RAMON=3
RAMONB=3
RAMSTATUS=15
When I add the following lines to my code:
uint32_t k=*((uint32_t volatile*)0x20003ffc); │
uint32_t j=*((uint32_t volatile*)0x20004000);
I can both acces k and j as expected:
(gdb) p k
$1 = 49439
(gdb) p j
$2 = 3738084845
(gdb) p &k
$3 = (uint32_t *) 0x20003f98
(gdb) p &j
$4 = (uint32_t *) 0x20003f94
Because both are located in the lower section
This happens when I want to read those addresses directly through gdb:
(gdb) x /d 0x20003ffc
0x20003ffc: 49439
(gdb) x /d 0x20004000
0x20004000: Cannot access memory at address 0x20004000
I use pyocd as gdb server and arm-none-eabi-gdb as client
