Bootloader Update fails (INSUFFICIENT_RESOURCES)
Hi Nordic forum.
We wanted to update the bootloader over the air. Initially, we had a very plain bootloader (the one provided in the example) but later we added a timer to reset to the application when no packets are received. Updating that bootloader worked.
Later we added a few lines of code to feed the WDT in the bootloader (since we plan to add the WDT in our application), but when we try to update that new bootloader over the air we get the following error:
Error: When writing 'EXECUTE' command to Control Point Characteristic of DFU Target: Operation code 4 (EXECUTE) failed on DFU Target. Result code 4 (INSUFFICIENT_RESOURCES)
I suspected this was due to space issues but I don't know what the limitations are but the hex file that works' size is 103804 and the one not working's size is 104074
We're using nRF52832, SDK ver 13.0, SD132 4.0.2 and nRFutil 3.3.2. Also, we're using the nRF52 HDK PCA10040 to update the bootloader to our device.
Thanks in advance
