From the SDK8 s110 device, I want to send the string("hello") to the other device via the uart, and in the meantime I want the battery voltage to come through uart.
I defined ;
static uint8_t index = 0;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if((data_array[index - 2] == 'm') && (data_array[index - 1] == 'V'))
for(int i=0 ; i<6; i++)
m_battery_level[i] = data_array[i];
case APP_UART_FIFO_ERROR:
static void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_DISABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud9600
APP_UART_FIFO_INIT( &comm_params,
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOW,
err_code);
I found the app_uart_put (uint8_t byte) function in app_uart_fifo.c, but I want to send a string. How can I send "Hello" string data over uart connection?
