For the last few months, I've been building code and testing it on an nRF52840 PDK. Our production hardware, however, will use the nRF52832, and so I need to compile my code against a different target, and program it on a custom board.
I tried to start simple: the blinky example. I can get the project to compile by replacing "52840" in the Makefile with "52832", and adding the following two lines in their respective sections:
CFLAGS += -DNRF52
ASMFLAGS += -DNRF52
Also, these lines were modified to point at the generic nrf52 rather than nrf52840 files:
SRC_FILES += \
$(SDK_ROOT)/components/toolchain/gcc/gcc_startup_nrf52.S \
$(SDK_ROOT)/components/toolchain/system_nrf52.c \
With those changes, the example compiles just fine, but when I program it to the custom board, nothing visible happens. If I try to debug it in Eclipse, it hardfaults:
Thread #1 57005 (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
HardFault_Handler() at 0x1792
<signal handler called>() at 0xfffffff9
__isr_vector() at 0x0
Is there a tutorial, or some sort of instructions, for successfully running the examples in the SDK on the nRF52832? I feel like I'm missing something simple.
