I am using power_manage function to keep low power sleep mode. And I used below peripherals in code,
- SPI master, SPI master is disabling when ever I am not using.
- Timer given in the example codes, i.e RTC1 timer and it will give 1 second timer interrupt.
- BLE connection mode. It will advertise connection packet for every 1 second.
- All unused GPIO pins configured as Output with pull down enabled, I tried all other ways this is the best I get in sense of less power consumption.
Based on these inputs can you please suggest, what is the reason of 20 micro Amps power consumption when CPU is in sleep?
