I'm developing a simple code that make use of timers using NRF-based boards and Arduino code.
The following code works fine on a Simblee nRF51822 board, but it crashes on a Adafruit Feather nRF52832 board (the variable 'flag' is never incremented).
long flag = 0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
Serial.println("setup");
timer_config();
void loop() {
// put your main code here, to run repeatedly:
Serial.println(flag);
delay(10);
void timer_config(void)
NRF_TIMER2->TASKS_STOP = 1; // Stop timer
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
NRF_TIMER2->PRESCALER = 9;
NRF_TIMER2->TASKS_CLEAR = 1; // Clear timer
NRF_TIMER2->CC[0] = 25000; // CC[0] register holds interval count value i.e your desired cycle
NRF_TIMER2->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos; // Enable COMAPRE0
Interrupt
NRF_TIMER2->SHORTS = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos); // Count then
Complete mode enabled
NVIC_EnableIRQ(TIMER2_IRQn);
NRF_TIMER2->TASKS_START = 1; // Start TIMER
void TIMER2_IRQHandler(void)
flag++;
if (NRF_TIMER2->EVENTS_COMPARE[0] != 0)
flag++; //Increment flag
NRF_TIMER2->EVENTS_COMPARE[0] = 0;
Any suggestion?
Thanks!
Simone
