Sleep between bytes on nRF52832 UART
Hi, I am a bit confused about power consumption when using app_uart_fifo. To save power I put MCU to sleep in between each sent and received byte by using __WFE and __SEV instructions. This helps but not as much as I expected. Code snippets are from receive mechanism but I get same behaviour when sending. As seen in picture 1 and 2 (attachmentsleeep_between_bytes.PNG) the current goes down between receiving each byte but the current peaks are much wider than the time it takes to receive each byte. I use GPIO:s to measure the time for handling the APP_UART_DATA_READY event in the event handler (picture 3, ~150ns) and the time it takes until app_uart_get() has executed (picture 4, ~5µs,). Baud rate is 115 200 and SDK version is 13.0.0. If I increase baud rate to 460 800 I can’t see any current dips at all between received bytes. I also tried another approach in which I stored received bytes in a temporary buffer directly from the event handler but the result was similar. So is this what I can expect with nRF52 or should it be possible to decrease the width of the current peaks with a more efficient implementation?
void uart_event_handler(app_uart_evt_t * p_event)
   if (p_event->evt_type == APP_UART_TX_EMPTY)
      tx_empty_flag = true;
   else if (p_event->evt_type == APP_UART_DATA_READY)
      nrf_gpio_pin_set(ARDUINO_0_PIN);
      nrf_gpio_pin_set(ARDUINO_2_PIN);
      data_ready_flag = true;
      nrf_gpio_pin_clear(ARDUINO_2_PIN);;
static void sleep_until_byte_received(uint8_t * byte)
   __WFE();
   __SEV();
   __WFE();
   if( true == data_ready_flag )
      while (app_uart_get(byte) != NRF_SUCCESS);
   nrf_gpio_pin_clear(ARDUINO_0_PIN);;
void receive_msg(msg_type_t * msg_type, uint8_t * seq_nr, uint16_t * msg_len, uint8_t * msg_buffer, bool * crc_err)
   /* get data bytes */
   if( *msg_type == REQ_FROM_KEY || *msg_type == RSP_FROM_CYL)
     for (uint16_t x = 0; x < rx_data_len; x++)
         sleep_until_byte_received(&received_byte);
         *(msg_buffer + x) = received_byte;
         receive_buffer[HDR_LEN + x] = received_byte;
         received_byte = 0;
BR Mattias
