i am checking NRF52840 for USB behaviour. I'm using example usbd_cdc_acm. But USB receiving stucks after few bytes (between 0 and 50) and does not receives nothing more.
I corrected the buffer size as recommended in devzone.nordicsemi.com/.../
Please provide some more information.
What SDK version are you using?
What version of the nRF52840 PDK are you using? It should be printed below PCA10056 on the sticker on the kit.
Do you have more than 1 nRF52840-PDK you can test with?
Do you have custom boards using "engineer samples" ?
If you are using engineer samples:
Problem is not by sending the bytes to the computer, but with receiving bytes from the PC.
From your description, I suspect it could be a issue with your nRF52840-PDK board. Please create a Mypage support case ticket regarding this issue, and we will find a solution for you. Remember to add the information about the board version in the MyPage ticket.
