Integrating DTM functionality into an app with softdevice
Hello, I am investigating the possibility of integrating the DTM functionality into our app (which uses the softdevice) to allow us to use a single image for production testing and deployment. What I am hoping to achieve is to allow a user to select/deselect DTM mode using a button press. It seems that this is only possible by disabling the softdevice, but I'm not clear whether that can be done inside the same app or whether the DTM part must be a distinct image that is booted into on the button press.
I have seen the following posts which seem contradictory to me:
Post 1 Post 2
Is the following feasible:
  1. Application running normally with softdevice
  2. User presses button
  3. Softdevice is disabled in the application and DTM functionality is enabled
  4. Some hardcoded DTM tests are run using dtm_cmd() and dtm_event_get() calls
  5. DTM test results are reported
  6. User presses button
  7. DTM functionality is disabled, softdevice is re-enabled
  8. Application running normally with softdevice
Or is it only possible to have the DTM functionality in a separate bootable image?
Thanks.
