Hello, this might be a stupid question but if I have a Bluetooth 5 module that is advertising and another module getting the RSSI-value without actually being connected to the BT5 module. Would the RSSI-value be affected depending on if the other module support BT 5 or only 4.2?
What I understand is that if the modules actually would connect to each other then they would agree on the latest version that both supports, which would probably affect the signal strength, but in the case above I’m not sure if the RSSI would be affected.
