I'm using nrf52 dev board on sdk version 14.0 with GCC compiler. I modified the hrs freertos example to add a simple thread with same priority as of logger thread. The new thread will just print a line and then suspend itself. The idle thread will then wake it up - just like logger thread.
As per my understanding, the new thread should keep on executing. But I see the print statements only 12 times. But when I debugging with gdb, the new thread is only executed twice. Afterwards, the debugger never hits the breakpoint set for the thread. When I force stopped the execution, the system is apparently executing a busy wait hoping for some interrupts } while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1]));
at external/freertos/portable/CMSIS/nrf52/port_cmsis_systick.c:294
Here is the code:
static void a_thread(void * arg)
UNUSED_PARAMETER(arg);
while (1)
NRF_LOG_DEBUG("Printing from the thread");
NRF_LOG_FLUSH();
vTaskSuspend(NULL); // Suspend myself
void vApplicationIdleHook( void )
vTaskResume(m_logger_thread);
vTaskResume(m_a_thread);
bool erase_bonds;
clock_init();
// Do not start any interrupt that uses system functions before system initialisation.
// The best solution is to start the OS before any other initalisation.
log_init();
#if NRF_LOG_ENABLED
// Start execution.
if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
// Activate deep sleep mode.
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
if (pdPASS != xTaskCreate(a_thread, "THREAD", 128, NULL, 1, &m_a_thread))
// Start FreeRTOS scheduler.
NRF_LOG_DEBUG("Starting FreeRTOS scheduler");
NRF_LOG_FLUSH();
vTaskStartScheduler();
while (true)
APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
What could be happening? Is something wrong with freertos configuration or is it my understanding ?
