I have a custom PCB board with a nRF52832 and a motion sensor. I cannot use a signal analyzer on the output from the sensor because of the shape and small size of PCB and its components and tools available. However, my board has a GPIO pin which I can use for testing (not used atm).
I was wondering if the GPIO module provides the capability to automatically "copy" an input signal (e.g. output signal from the sensor) to another GPIO pin (set as output for test purposes).
I know I can set an interrupt handler on such input pin and manually "copy" the pin value to the test one. However, I would like to know if it is possible to handle this situation via hardware without using software.
Thank you for any suggestion.
Regards, Marco
