gpiote interrupt resolution
Can NRF52 gpiote detects pulse width nearly 250ns? We use a AFE sensor that notifies MCU it's data by sending a low to high pulse. The pulse width is about 250ns which is very small, I set the gpio triggering interrupt from low to high,but NRF52 can't run into the interrupt?
    Have you looked at the pulses with an oscilloscope and made sure they go high enough to register as a logic high on the nRF52? The pulse must cross Vdd * 0.7.
    I used an nRF52 DK and this code to measure pulses shorter than 250ns:
    void GPIOTE_IRQHandler(void)
        nrf_gpio_pin_toggle(LED_1);
        NRF_GPIOTE->EVENTS_IN[0] = 0;
        NVIC_ClearPendingIRQ(GPIOTE_IRQn);
        LEDS_CONFIGURE(LEDS_MASK);
        LEDS_OFF(LEDS_MASK);
        nrf_gpio_cfg_input(BUTTON_1, NRF_GPIO_PIN_PULLUP);
        NRF_GPIOTE->INTENSET = 1;
        NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos |
                 3 << GPIOTE_CONFIG_PSEL_Pos |
                 GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos;
        NVIC_EnableIRQ(GPIOTE_IRQn);
        while (true)
            __WFE();
    As long as you cross Vdd * 0.7, 250ns shouldn't be a problem.
  • Hi,Martin, Thanks for your reply. I added your code after my gpiote configuration code, then I found the problem.since nrf_drv_gpiote_init()was not called, nrf_drv_gpiote_in_init()returned on pin_in_use_by_gpiotechecking. It's my fault. Now it's working. Thanks again!
