Softdevice and interrupt lost
Hi everyone, My configuration:
  • nrf52832 microcontroller
  • Softdevice S132 V4.0.2
  • Nordic SDK 13.0
  • IDE: Eclipse
I'm working with a "Stand-alone can bus controller" connected to nrf52832 with SPI interface. The CAN controller informs nrf52 micro, via an interrupt pin, that a “CAN packet" was received on the stand-alone controller. I analyzed that interrupt events are very frequent (about 500us). Interrupt pin is configured as input interrupt pin using GPIOTE:
void can_controller_interrupt_pin_init(uint8_t pin_int)
    ret_code_t err_code;
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.pull = NRF_GPIO_PIN_NOPULL;
    err_code = nrf_drv_gpiote_in_init(pin_int, &in_config, can_controller_int_pin_handler);
    nrf_drv_gpiote_in_event_enable(pin_int, true);
My problem is:
  • During BT advertising, interrupt requests coming from CAN controller, are correctly detected.
  • During BT connection, interrupt requests coming from CAN controller, are discarded.
It seems that Softdevice gives high priority to BLE connection and ignore interrupts.
How can I resolve this problem, without using a "polling solution"?
GATT Configuration:
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      360                                     /**< The advertising timeout (in units of seconds). */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)         /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(6000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
SPI Configuration:
ret_code_t spi1_init(void)
	nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
	/* SPI Parameters */
	spi_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;
	spi_config.miso_pin = SPIM1_MISO_PIN;
	spi_config.mosi_pin = SPIM1_MOSI_PIN;
	spi_config.sck_pin  = SPIM1_SCK_PIN;
	spi_config.orc  	= 0x00;
	spi_config.frequency = NRF_DRV_SPI_FREQ_4M;
	spi_config.mode      = NRF_DRV_SPI_MODE_0;
	spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
	m_spi1.m_spi_instance = spi1;
	m_spi1.m_spi_xfer_done = true;
	/* Function for initializing the SPI master driver instance. */
	err_code = nrf_drv_spi_init(&spi1,
								&spi_config,
								spi1_event_handler,
								NULL);
	m_spi1.m_init = (err_code == (NRF_SUCCESS)||NRF_ERROR_INVALID_STATE)? true : false;
	return err_code;
Interrupt routine:
void can_controller_int_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	flag_can_msg = true;
Many thanks!
