I am implementing ContikiOS on my custom nRF52823 board. I have been following the instruction here: github.com/.../README-BLE-6LoWPAN.md
I am running Debian 9 testing. I modified the header file pca10040.h
to use different pins for LEDs.
Everying is going well but at the last step, i can't ping the device. I can scan it using hcitool lescan
and connect to the device using echo "connect 00:E1:F8:BE:70:DA 1" > /sys/kernel/debug/bluetooth/6lowpan_control
. Here is the result of ifconfig
root@myDeb:/home/elecfist# ifconfig
bt0: flags=4161<UP,RUNNING,MULTICAST> mtu 1280
inet6 fe80::780c:b8ff:fec7:a082 prefixlen 64 scopeid 0x20<link>
unspec 78-0C-B8-C7-A0-82-00-A7-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 15 bytes 1183 (1.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
The bt0 interface is also present and up. The leds also indicate that i have connected to be board. The command ping6 -I bt0 fe80::2e1:f8ff:febe:70da
returns something like this.
root@myDeb:/home/elecfist# ping6 -I bt0 fe80::2e1:f8ff:febe:70da
PING fe80::2e1:f8ff:febe:70da(fe80::2e1:f8ff:febe:70da) from fe80::780c:b8ff:fec7:a082%bt0 bt0: 56 data bytes
From fe80::780c:b8ff:fec7:a082%bt0 icmp_seq=1 Destination unreachable: Address unreachable
From fe80::780c:b8ff:fec7:a082%bt0 icmp_seq=2 Destination unreachable: Address unreachable
From fe80::780c:b8ff:fec7:a082%bt0 icmp_seq=3 Destination unreachable: Address unreachable
^C
--- fe80::2e1:f8ff:febe:70da ping statistics ---
5 packets transmitted, 0 received, +3 errors, 100% packet loss, time 4088ms
How do I troubleshoot this problem?
