Coming from other embedded systems, I'm impressed with the flexibility and power of the Task/Event framework of the nRF52832. But with great flexibility comes great confusion! :)
I'd like to do something along these lines, written here in pidgin C:
for (int i=0; i<12; i++) {
gpio_set(PIN_A);
gpio_clr(PIN_B);
pause_briefly();
dma_buf[2*i] = saadc_read();
gpio_clr(PIN_A);
gpio_set(PIN_B);
pause_briefly();
dma_buf[2*i+1] = saadc_read();
My best guess as to translating this into Tasks and Events:
- Configure PWM to drive PIN_A inverted and PIN_B non-inverted.
- Set PWM LOOP.CNT to 24
- Use ??? to trigger an SAADC TASKS_SAMPLE [*]
- Use DMA to write SAADC samples into RAM
- Use PWM's EVENTS_LOOPSDONE to trigger interrupt in user code
[*] I think I can use a second PWM channel to toggle its output shortly after setting PIN_A and PIN_B and use that to generate an Event. This event give PIN_A and PIN_B a chance to settle before triggering the SAADC read. As long as I can use any of the channel outputs to generate an event I should be okay.
So the questions:
Is this more or less the right approach? What are some good examples to use as starting points? Any gotchas I should be aware of?
My environment:
- nRF54 dev board
- nRF5_SDK_14.2.0
- SEGGER Embedded Studio Release 3.30
- macOS High Sierra 10.31.1
