NRF52840 Coded Phy Sensitivity with soft device 6.0.0-6.alpha
although the NRF52840 has a nominal receiver sensitivity of -103 dbm I am only able to get a sensitivity of around -97 dbm. I know there was a bug in older soft device versions resulting in a decreased sensitivity, but I am using soft device 6.0.0-6.alpha in which this bug should be fixed. I used a modifiedatt_mtu_throughput example to print the RSSI when changed, but connection between two nrf52840 boards is still lost at around -97 dbm.
Is there anything else that needs to be considered apart from the soft device version?
Thanks in Advance
Christian
