All of a sudden (isn't it always the case :) the JLink debugger fails to flash the app code to the dev kit (PCA100028) The Project's softdevice is flashing well without any problem and so does sample projects so the problem is not with the hardware..
Error dialog says "No Cortex-M device found in JTAG chain" Output window message says "RESET high but should be low"
Power cycles do not help (though, as mentioned, the hardware works well with other projects and same project softdevice flashing).
What can be the problem? What project propert (in projetc configuration dialogs) could go wrong and cause this behavior ?
Thanks for any advice. Any thoughts?
Thanks
