Hey guys,
I'm trying to make the FDS work with BLE and the scheduler. But something doesn't right when I use the Softdevice and scheduler with the FDS.
Must I register something in my ble_stack_init()
, I read something about sys_evt_dispatch()
to softdevice_sys_evt_handler_set():
I'm using SDK 14.1 with the Softdevice S132 v5.0.0 on a NRF52832.
I hope you guys can help me.
Here is a part of my code:
fds_evt_handler()
static void fds_evt_handler(fds_evt_t const * p_evt)
NRF_LOG_INFO("Event: %s received (%s)",
fds_evt_str[p_evt->id],
fds_err_str[p_evt->result]);
switch (p_evt->id)
case FDS_EVT_INIT:
if (p_evt->result == FDS_SUCCESS)
NRF_LOG_INFO("FDS_EVT_INIT");
m_fds_initialized = true;
} break;
case FDS_EVT_WRITE:
NRF_LOG_INFO("FDS_EVT_WRITE");
} break;
case FDS_EVT_DEL_RECORD:
NRF_LOG_INFO("FDS_EVT_DEL_RECORD");
} break;
fds_write()
void ncs_record_write(uint32_t fid, uint32_t key, void const * p_data, uint32_t len)
ret_code_t err_code;
fds_record_t const rec =
.file_id = fid,
.key = key,
.data.p_data = p_data,
.data.length_words = (len + 3) / sizeof(uint32_t)
NRF_LOG_INFO("Writing record to flash...\r\n"
"file: 0x%x, key: 0x%x, \"%s\", len: %u bytes\r\n",
fid, key, p_data, len);
err_code = fds_record_write(NULL, &rec);
if (err_code != FDS_SUCCESS)
NRF_LOG_INFO("Error: ncs_record_write() returned %s.\r\n",
fds_err_str[err_code]);
fds_read()
void ncs_record_read(uint32_t fid, uint32_t key)
fds_flash_record_t config = {0};
fds_record_desc_t desc = {0};
fds_find_token_t ftok = {0};
if (fds_record_find(fid, key, &desc, &ftok) == FDS_SUCCESS)
/* Open the record and read its contents. */
err_code = fds_record_open(&desc, &config);
memcpy(&_ncs_settings.buffer, config.p_data, sizeof(config.p_data));
NRF_LOG_INFO("Record found: %u", _ncs_settings.buffer);
/* Close the record when done reading. */
err_code = fds_record_close(&desc);
NRF_LOG_INFO("Record not found!");
fds_setup()
static ret_code_t fds_setup(void)
err_code = fds_register(fds_evt_handler);
err_code = fds_init();
return NRF_SUCCESS;
wait_for_fds_ready()
static void wait_for_fds_ready(void)
while (!m_fds_initialized)
power_manage();
scheduler_fds_write()
static void scheduler_fds_write(void * p_event_data, uint16_t event_size)
UNUSED_PARAMETER(p_event_data);
UNUSED_PARAMETER(event_size);
ncs_record_write(ncs_settings.file, ncs_settings.key,
(void *)ncs_settings.buffer, sizeof(ncs_settings.buffer));
NRF_LOG_INFO("FDS data written!");
scheduler_fds_read()
static void scheduler_fds_read(void * p_event_data, uint16_t event_size)
ncs_record_read(ncs_settings.file, ncs_settings.key);
NRF_LOG_INFO("FDS data readed!");
main()
bool erase_bonds;
// Initialize
log_init();
timers_init();
ble_stack_init();
scheduler_init();
gap_params_init();
gatt_init();
peer_manager_init();
services_sr_init();
advertising_init();
db_discovery_init();
services_init();
conn_params_init();
gpiote_init();
saadc_init();
twi_init(SCL_PIN, SDA_PIN);
err_code = fds_setup();
wait_for_fds_ready();
// Reading Battery first time
err_code = nrf_drv_saadc_sample();
ncs_settings.sync = 5;
ncs_settings.buffer = ncs_settings.sync;
ncs_settings.file = 1;
ncs_settings.key = 1;
err_code = app_sched_event_put(NULL, 0, scheduler_fds_write);
// err_code = app_sched_event_put(NULL, 0, scheduler_fds_read);
// read_error(err_code);
// APP_ERROR_CHECK(err_code);
// Start execution
NRF_LOG_INFO("nxta Cube started.");
advertising_start(erase_bonds);
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
// Enter main loop
for (;;)
app_sched_execute();
power_manage();
if(m_cur_conn_handle != BLE_CONN_HANDLE_INVALID)
if(nxtaEvent.pending)
handle_nxtaEvent(&nxtaEvent);
Thanks in advance :)
UPDATE 22.12.2017 I updated the code a little bit
