Could not find AHB-AP to communicate with Cortex-M core
Update: Hi again to everyone!
After a while, I've received a new custom board and a new cable to connect through P19. But everything are not working again.
Now, in nRFgo, when I click in Segger (under nRF52 development boards) I receive a message in bold: "No device detected or readback protection may be set"
If I press the recover button, an unknown error occurss.
Maybe I have to change something, in the development board, to be able to program the custom board?
Original post: Hi to everyone!
I have been testing and programming a nRF52832DK board (Bluetooth, SPI, NFC, ...) with, at the beginning problems and learning how to fix them, and in the end everything works successfully.
I am been programming in Keil uVision 5 and using this program to upload the code compiled to the development board and nRFgo Studio to program the SoftDevice binaries.
Ok, everything works fine.
Now I have a custom board (with nRF52832) and I want to upload a simple code to test I can work with it.
But I do not know if I can upload the code in the same way that I uploaded in the development board (with Keil).
Also I do not know if I can debub in the same way (I am using J-Link RTT Viewer, selecting SWD as target).
After wiring all connections in P20 on the development board (to custom board), when I power the custom board, power on the development board and trying to upload the code from Keil (or connecting through J-Link RTT Viewer or J-Link Commander) I always receive the same error:
"JLink Error: Could not find AHB-AP to communicate with Cortex-M core. Communication timed out: Requested 20 bytes, received 0 bytes ! Could not read hardware status!"
image description
Also, in the Keil, I receive: "No Cortex-M SW Device Found".
image description
(If I do not power the custom board, everything works fine, because I am working with development board and this board does not detect the custom board).
Any Idea where the problem might be?
Could it be a bad wiring or something like that?
Thanks in advance!
