I use a nRF52832 device, and I have some strange behavior when I use PWM. You can see my test program listed below.
Thank for your reply, Thierry!
* Test_PWM.c
* Created on: 13 déc. 2017
* Author: Thierry
#include <system.h>
#include <nrf_drv_pwm.h>
#include <nrf_drv_gpiote.h>
#include <nrf_drv_ppi.h>
/* BUG : PWM
* SEQ[1].REFRESH is ignored if the samples size is equal to one.
* The PWM should generate a signal waveform described as following.
* It's composed of 4 samples with one pulse each and 4 samples with zero level.
* __ __ __ __
* __| |____| |____| |____| |___________________________________....
* <---------- seq0 -------------->
* <---------- seq1 --------------->
* and the result is wrong !
* __ __ __ __
* __| |____| |____| |____| |__________....
* <-seq1->
* But, if I add more than one sample on the SEQ1 ( pwm1_seq1_values[] ), the problem doesn't occur
* and the number of repeats is corresponding to pwm1_seq1.repeats value.
#ifndef PWM1_ENABLED
#error "PWM1 should be enable in sdk_config.h!"
#else
static nrf_drv_pwm_t pwm1 = NRF_DRV_PWM_INSTANCE(1);
#define GPIO_OUTPUT_TEST_PIN (3) // P0.03
#define FREQ_PWM (125E3)
#define PWM_TOP (FREQ_PWM*0.25) // 31250 (maxi 15 bits)
#define PWM_CH0 (FREQ_PWM*0.15) // DEBUG
/* RAM location */
static nrf_pwm_values_common_t pwm1_seq0_values[] = {
(PWM_CH0)
static const nrf_pwm_sequence_t pwm1_seq0 =
.values.p_common = pwm1_seq0_values,
.length = NRF_PWM_VALUES_LENGTH(pwm1_seq0_values),
.repeats = 3, // < -- 4 samples for sequence 0
.end_delay = 0
/* RAM location */
static nrf_pwm_values_common_t pwm1_seq1_values[] = {
(PWM_TOP),
// (PWM_TOP), // < -- workaround!
// (PWM_TOP),
// (PWM_TOP),
static const nrf_pwm_sequence_t pwm1_seq1 =
.values.p_common = pwm1_seq1_values,
.length = NRF_PWM_VALUES_LENGTH(pwm1_seq1_values),
.repeats = 3, // < -- 4 samples for sequence 1 : ignored if samples size is one
.end_delay = 0
static const nrf_drv_pwm_config_t pwm1_config =
.output_pins =
GPIO_OUTPUT_TEST_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0
NRF_DRV_PWM_PIN_NOT_USED,
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_125kHz,
.count_mode = NRF_PWM_MODE_UP_AND_DOWN,
.top_value = PWM_TOP,
.load_mode = NRF_PWM_LOAD_COMMON,
.step_mode = NRF_PWM_STEP_AUTO
static void test_pwm_init(void) {
ret_code_t error;
// Init PWM without irq handler
error = nrf_drv_pwm_init(&pwm1, &pwm1_config, NULL); // NULL : don't use pwm_handler
APP_ERROR_CHECK(error);
error = nrf_drv_pwm_complex_playback(&pwm1, &pwm1_seq0, &pwm1_seq1, 1, NRF_DRV_PWM_FLAG_LOOP);
void Test_PWM(void) {
test_pwm_init();
