I am trying to control a current measurement chip (DDC114) that works with a protocol that is close (enough) to SPI. It has 2 channels, s.t. it can be read out and integrating at the same time. The switch between the channels is performed by an external square wave signal that sets the integration time. I implemented this using a 50% duty cycle PWM. During half a period I need to clock out 80 bits via SPI. My problem is that the PWM signal is constantly drifting w.r.t. the SPI clocks. I can tolerate a bit of shifting (couple of us) but not that the SPI clocks fall into a different half period of the PWM signal. How can I sync them in phase?
Here is the code I use to test it.
#include <sys/param.h>
#include <string.h>
#include "variables.h"
#include "sdk_config.h"
#include <nrf_drv_spi.h>
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include <string>
using namespace std;
#include "app_pwm.h"
void pwm_ready_callback2(uint32_t pwm_id){}
void run_test(){
ret_code_t err_code;
APP_PWM_INSTANCE(PWM1,1);
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(2*100, 25);
pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback2);
app_pwm_enable(&PWM1);
app_pwm_channel_duty_set(&PWM1, 0, 50);
nrf_drv_spi_t m_spi_master_1 = NRF_DRV_SPI_INSTANCE(1);
nrf_drv_spi_config_t spi_config2 = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config2.ss_pin = -1;
spi_config2.miso_pin = DDCDOUT;
spi_config2.mosi_pin = SDO;
spi_config2.sck_pin = CLK;
spi_config2.frequency = NRF_DRV_SPI_FREQ_2M;
spi_config2.mode = NRF_DRV_SPI_MODE_0;
err_code = nrf_drv_spi_init(&m_spi_master_1, &spi_config2, NULL);
uint8_t payload[10];
//loop it so I can see it better on the oscilloscope
for (int i = 0; i < 20000 ; i++) {
err_code = nrf_drv_spi_transfer(&m_spi_master_1, NULL, 0, &payload[0], 10);
nrf_delay_us(500);
nrf_drv_spi_uninit(&m_spi_master_1);
int main(){
run_test()
