Inaccurate timer interrupt
I am working on nRF52840 Preview DK. I want to generate a square wave with accuracy of ON and OFF time = 1 microsecond using timer for driving stepper motor DRB8825.
I am using SDK version : nRF5_SDK_14.2.0_17b948a
I have performed below set of experiments,
Exp 1. Configure timer to generate interrupt after every 1us and toggle port pin p0.13 in interrupt service routine.
 Observations : Port pin is toggled after every 3us instead of 1us with jitter (varying ON and OFF time).
 Question : Why interrupt handler is called after 3us instead of 1us? How to remove the jitter.
Exp 2. Integrate timer in ble_app_uart (softdevice version used : s140_nrf52840_5.0.0-2.alpha), configure timer to generate interrupt after every 1us and toggle port pin p0.13 in interrupt service routine.
 Observations : Port pin is toggled after every 16us instead of 1us with increase in jitter.
Question : Why the interrupt handler is called after 16us instead of 1us? why ISR calling time is increased as compared to Exp 2 after integrating bluetooth? Why jitter is increased?
Exp 3. Integrate timer in ble_app_uart. Generate square wave of 1us ON and OFF time using GPIOTE, timer3 and PPI on port pin p0.13 and toggle port pin p0.14 in interrupt service routine of timer3.
 Observations : p0.13 is toggled after every 1us accurately with no jitter using PPI module of the controller, p0.14 is toggled after every 16us with jitter.
Exp 4. Integrate timer in ble_app_uart. Generate square wave of 50us ON and OFF time using GPIOTE, timer3 and PPI on port pin p0.13 and toggle port pin p0.14 in timer3 interrupt service routine.
Observations : p0.13 is toggled after every 50us accurately with no jitter, p0.14 is toggled after every 50us with jitter.
   Question : p0.13 and p0.14 should be toggled at the same time as they are based on same timer3, why ther is jitter in toggling p0.14
Exp 5. Integrate timer in ble_app_uart. Generate square wave of 10us ON and OFF time using GPIOTE, timer3 and PPI on port pin p0.13. Stop generating square wave after 4 cycles by disabling timer, ppi and gpiote in timer3 interrupt service routine.
Observations : p0.13 is toggled after every 10us accurately with no jitter, but it takes some time after 4 cycles to stop generating waveform.
Question : How to stop generating waveform exactly after 4 cycles.
I have to generate accurate time period of square wave(lets say 1us) & predefined number of cycles(lets say 8 pulses) for controlling motor. However, I am not able to control the generation of desired number of square wave pulses with PPI.
  • It should be apparent that a 64MHz processor can not process microsecond interrupts. Apparently this is not obvious to people (it should be) since this comes up regularly.
    Please search through the devzone and you will find countless questions on microsecond gpio activity and how it CAN NOT be done via interrupts with a 64MHz processor. It can only be done via PPI/GPIOTE.
