I'm trying to prototype an application on the nRf52 DK (PCA10040) using the GCC toolchain. I followed all of the tutorial for setting things up and I can build and flash things fine, but I don't think the application is working correctly.
I'm starting with the HID keyboard example as a baseline. I have not modified any of the source and it builds without errors. The application comes up, the light blinks, but my phone (galaxy S8) cannot see the device. I can occasionally see the device in nRF connect, but the advertisment frequency nRF connect shows does not jive with the configured advertising intervals of 25ms / 2 seconds in the example.
If I flash the board with the hex files provided with the examples everything works nicely. I'm guessing the examples were not built with GCC? I'm thinking this may be the problem may be with the tool chain. I, perhaps foolishly, grabbed the newest version of the GNU ARM (6 2017-q2-update). Are there any known issues with this version? Or is there an older version that is recommended?
I've tried SDK versions 12.3 and 14.2, with the same results
Thanks, Josh
Edit 1: Here is the hex file I referenced in the comment below, couldn't attach to a comment for some reason. Hex file
