Is there a demo project that contains RTC function with softdevice. I called the lfclk_config() and rtc_config() function before softdevice initial in main(), but it could not pass through SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL). How can I sovle this issue, am I missing some settting?
void lfclk_config(void)
ret_code_t err_code = nrf_drv_clock_init();
void rtc_config(void)
uint32_t err_code;
//Initialize RTC instance
nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
config.prescaler = 4095;
err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
//Enable tick event & interrupt
nrf_drv_rtc_tick_enable(&rtc,true);
//Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
//Power on RTC instance
nrf_drv_rtc_enable(&rtc);
